Attaching clothes and hair to a rigged body
21733 72 3-
- ALMINA
- 154 posts
- ALMINA
- 154 posts
- ALMINA
- 154 posts
Okay by everyones help I finally got to this point. I copied the weight file directly and recaptured it and then locked the capture meta node.
Now all I have got to do is input the “metaCaptGroups” into the attribute transfer node.
Does anyone have any suggestions of how to do it?
Thank you very much everyone for a long time by the way
- ALMINA
- 154 posts
- ALMINA
- 154 posts
- matthias_k
- 483 posts
If you change something above the capture meta sop
you have to unlock it and you must got to the frame
which is set as “Capture Frame” in the capture meta sop.
For transfer the order is maybe not correct.
Was Metaball set as target, while capturing?
- matthias_k
- 483 posts
- ALMINA
- 154 posts
- ALMINA
- 154 posts
- malbrecht
- 806 posts
Hi, Matthias,
just wanted to state this here: Thank you for the patience and great support you are doing here on the forum - I am a Houdini greenhorn myself and merely fiddling my way through a completely new world. Seeing someone so willingly chiming in and helping another newbie is *great* moral support!
@Almina: I am lost about how to really help you. One thing would be to just get your setup working for you, but I am afraid that wouldn't really *help* you, because you seem to want to cross the finish without running all the rounds. The other approach does not seem to work for you: Trying to get you over the steps involved in a complete setup.
If your scene, even in a simplified version, is too big to upload it here, why don't you use a free Dropbox account or something like that? It is really hard *guessing* what is going wrong, especially when you seem to miss (really basic) steps like actually enclosing the geometry in the capture regions.
Please try to help us helping you. Break down your setup. E.g. cut off everything but an ARM. Understand how to rig and cloth-rig that. Then transfer what you learned from that to the rest of the body. Learn procedurally (sorry, couldn't resist)
Marc
Marc
Good bye.
Good bye.
- ALMINA
- 154 posts
Thank you Marc and Matthias and sorry for the inconvenience when you are trying to help me…
And Thank you for pointing out drop box! Never thought about that!
https://www.dropbox.com/s/xizmld09qgmmg8u/Test_Weight_Attribute_Transfer.zip?dl=0 [dropbox.com]
Here is the link! Please tell me if you cannot download the file or any problems!
- matthias_k
- 483 posts
Hi malbrecht, many thanks :-)
@Almina, I can have a closer look today in the evening,
but first look says:
/obj/Main_Character_deform_rig/skin/file__read_in_skin
is missing…. and: is this a v13 Biped AutoRig?
The Main_Chracter.otl or where does it com from?
- matthias_k
- 483 posts
- ALMINA
- 154 posts
- ALMINA
- 154 posts
- matthias_k
- 483 posts
- ALMINA
- 154 posts
- edward
- 8115 posts
- matthias_k
- 483 posts
- matthias_k
- 483 posts
