Cloudy liquid shading
3355 7 0-
- Simon van de Lagemaat2
- 116 posts
- 9402 posts
- 116 posts
tamte
yes, uniform volume will do
maybe exclude your glass/liquid object from shadow casting or at least turn of faux caustics to allow light to illuminate your uniform volume object
Okay I managed to figure out what was going on. I was applying the uniform volume material via a material node, that wasn't working, I had to apply it on the item level. That seems buggy to me…?
Thanks for the reply.
owner the Embassy VFX
- 8177 posts
- 9402 posts
jsmackwhat do you mean? for non-uniform you just create actual volume with traditional volume shader (instead of using poly+uniform volume properties) but of course boundaries may not align perfectly
What about non-uniform? Custom pathtracer the only way?
the shadow part is the same, unless you are brave enough to enable all paths
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- 8177 posts
tamtejsmackwhat do you mean? for non-uniform you just create actual volume with traditional volume shader (instead of using poly+uniform volume properties) but of course boundaries may not align perfectly
You would need to make the volume only visible to refraction rays or some such, but I'm not sure how to make the volume not occlude shadow rays when outside the polys. Maybe trace in -I to see if it hits a surface with N facing in that direction. You can't just rely on volume values to define the border, it has to be traced.
- 116 posts
- 8177 posts
