I have a curve(s) that I am “trimming” by using adjustPrimLength in a wrangle.
I need to find a way to select/group the points at a variable percentage from the growing/shrinking end of the curve.
If I were using carve to do this I would probably just do a distance measurement between the carve location and the points on the curve, but I cant do that here as I am working with multiple primitives of different length.
Trying to think of some handle I can use to identify the current endpoint on each primitive…
I suspect this is really easy but it is escaping me at the moment.
tia
Jeff
select points on a curve based on curve length or current end point
3991 3 0- jeffMc
- 125 posts
- jeffMc
- 125 posts
I moved a bit farther along here but still having some troubles. Maybe I should re post but I would like to change the question a bit.
I have several curves, each with a unique start point. I need to add a distance based attribute based on the start point to each individual point on that primitive. I am thinking for next loop but wondering if there is another more efficient approach?
- sl0throp
- 258 posts
- jeffMc
- 125 posts
