VEX: How to define a global variable and pass it to a function
   10694   4   2
I'm quite new to coding and I'm trying to pass variables to my user-defined function, but I get the error “Variable is not accessible in this function”. I want to define global variables on top, create local variables in the function and then pass the calculated value to the global variables. The function also returns another value, but I need actually three values in my main program that will be calculated in the function. Below is a simplified example of what I mean:
// define global variables
float ao = 0;
float bo = 0;
int mand(float x, y){ //user-defined function
int a = x/2;
int b = y/3;
int i = a+b;
ao = a; // pass values a to global variable ao
bo = b; // pass values b to global variable bo
return(i);
v@Cd = set(ao, bo, mand(1, 0.3)); // use variables ao and bao in main program, as well as i, for example in color attribute
Is it somehow possible to access global variables in my function? It worked like this in Javascript. Or is there a possibility to return three values from my function and use them all later?
As far as I know you can't access a variable outside a function directly.
It needs to be passed to the function if you want to change it, which is what I usually do.
I've also changled your code a bit for a and b, casting them as ints.
float ao = 0;
float bo = 0;
int mand(float x, y, ao, bo){ //user-defined function
int a = int(x/2);
int b = int(y/3);
int i = a+b;
return(i);
v@Cd = set(ao, bo, mand(1.0, 0.3, ao, bo)); // use variables ao and bao in main program, as well as i, for example in color attribute
Perhaps constants would work:
#define MY_INT            123
#define otherInt 999
int foo( float ax; ) {
int val = (ax > 0) ? MY_INT : otherInt;
return(val);
i@a = foo(@P.x);
I'm o.d.d.
BabaJ
Great approach to pass them. Thanks a lot!
Now I still had the problem that the ao/bo variables are not changed to a/b for the main program when I set the colors. Is it actually possible to return three values? I now figured it out to do it by returning a vector and then accessing each value in it seperately in the main program and it works.
Edited by viviana_aline - July 30, 2017 08:44:04
a/b are ‘changed’…I think what is happening and you didn't realize is that your x/2 and y/3 are divisions by integers.
I assumed you were doing this intentionaly creating your own ‘floor’.
That is why I added the casting of int to your two lines of code.( just to get rid of Houdinis' ‘green warnings’ )
Change your int variables in the function to floats and do your divisions by a float:
int a = int(x/2.0);
int b = int(y/3.0);
As far as I know it isn't….
Yeah that's a good way to do it…also…in the future if you want to ‘return’ more than 3 values, you could also return an array of values and post process individual items with indexing.
Edited by BabaJ - July 30, 2017 09:34:22
