The snippet
int test(int a;int b=2)
return a+b;
returns invalid default value for parameter b error
Is there a way to have default values for function arguments in vex snippets?
Default values for function arguments in vex snippets error
4858 5 1-
- pashakabush
- 17 posts
- BabaJ
- 2164 posts
- 9387 posts
if you expect it to work like python and being able to just omit b to get the defaults, then it's not automatic
you can however create the representation of the function with just a and use default value for b inside
like this:
like this:
int test(int a;int b) { return a+b; } int test(int a) { int b = 2; return test(a, b); } printf("%g\n", test(1)); // returns 3 (1 + default 2) printf("%g\n", test(1,1)); // returns 2 (1 + 1)
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- lizardstailz
tamte
like this:int test(int a;int b) { return a+b; } int test(int a) { int b = 2; return test(a, b); } printf("%g\n", test(1)); // returns 3 (1 + default 2) printf("%g\n", test(1,1)); // returns 2 (1 + 1)
That's exactly what i did)
Still it's strange that this example errors out in snippets
taken from http://www.sidefx.com/docs/houdini/vex/lang [www.sidefx.com]
surface noise_surf(vector clr = {1,1,1}; float frequency = 1; export vector nml = {0,0,0}) { Cf = clr * (float(noise(frequency * P)) + 0.5) * diffuse(normalize(N)); nml = normalize(N)*0.5 + 0.5; }
- 9387 posts
lizardstailzI don't think you can define a shader in the snippet
snippet already runs within the context function
so you can use just normal VEX functions, which don't have default values for arguments
Edited by tamte - Oct. 30, 2017 17:25:16
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- pashakabush
- 17 posts
