I modeled a model in houdini 16.0.671 and exported it as fbx then I imported the mesh into Unreal 4.18 and I got a Waring error that says " No smoothing group found " but unreal still imports it and when I bake lightmaps no issue found on the model but with that does it mean that everything is fine consigning the import process? if not please what is the solution to remove that error ?.
Thank you for your reply.
Chiaka Chima.
Houdini to Unreal Import issue: "No smoothing goup found"
584 0 1- chiako3D
- 3 posts
