Hi there,
I'm pretty new to Houdini and currently trying to render an image on a high res A1 size 300 dpi.
I inserted all the parameters for the new resolution and ticked the overrides box but when I render to Mplay the render resolution is still the low one. Can't work out if there's anything else I should be doing?
Thanks in advance!
Render high res images with Mantra
2328 1 0-
- Yael
- 8380 posts
Resolution is limited in the Apprentice licensed version. An indie or above license is needed to lift the restriction for still images, and a full commercial license is needed to render sequences without restriction.
https://www.sidefx.com/filmtv/compare/ [www.sidefx.com]
