Hey Guys,
is the update Button still not working under 16.5.378?
I am wondering if that is still the case or if i am doing something wrong?
All the best!
Game Toolset Button not working under 16.5.378
6452 10 0-
- anon_user_58123709
- 86 posts
- ipninichuck
- 11 posts
- lkruel
- 240 posts
Could you give us a bit more info.
What OS are you running and at what point do you get the error, just clicking on the button, or after selecting something on the dialog?
The previous errors were related to Https failing, but those errors should be fixed as far as we're aware.
Thanks for the report and let us know
Luiz Kruel
Senior Technical Artist
- 86 posts
Hi Luiz,
thank you for your quick response.
I am sorry i did not provide any more information right away!
What happens for me is this:
I installed the latest update for Houdini and the GameDev Tools were already installed for the prior versions. While installed i chose to delete the previous version of Houdini.
When i started the new version of Houdini for the first time. The tools were loaded and work!
But if i click the Updater Button Houdini just freezes and wont respond anymore.
Then i force close it and if i start it again the tools have disappeared - only the Update Button left.
Clicking the Update Button then also brings up the same problem. Houdini wont respond anymore.
I am not at home now - but i am pretty sure if i would delete and reinstall the GameDev Tools manually it would work again - as long as i dont use that Updater Button!
My OS is Windows 10.
Thanks for all the hard work and for responding so quick!
Much appreciated!
I hope i did not miss anything!
Much appreciated!
Edited by anon_user_58123709 - Feb. 12, 2018 01:22:38
- lkruel
- 240 posts
Alright, so it's possible that you have an older version of the games tools lying around causing trouble.
In your Documents/Houdini16.5 folder, delete gamedevtoolset.json and make sure your houdini.env doesn't have any references to the gamedev stuff.
Restart Houdini and try the Update Button again
Let me know if that fixes you
Luiz
Luiz
Luiz Kruel
- 86 posts
Hi Luiz,
thank you so much for taking the time to walk me through this!
I am starting to think the issue is somewhere on my end.
So i deleted Houdini completely including all folders etc. and reinstalled the new version.
After i tried to download the tools via Houdini using the Update Button.
I have attached a image of the error message i now get.
Sorry, if this is basic stuff :*
- lkruel
- 240 posts
- 86 posts
- 86 posts
Hi Luiz,
i just got home and tried what you said right away!
Major twist - the url was just a http - without the s.
Updating the toolset worked by putting IN the “s” for me!
Then after installing the toolset - its in there without the “s” (just http)
If you try to update again - it wont work again (but tools will still be available when you restart)
Then putting in the “s” again (https) makes it work again!
Could that be the clue? So that in the script its always https (for now)
Because everytime i update it switches back to “http” and then it wont work.
With “https” it works!
Hope this helps!
Hope this helps!
- Barrett Meeker
- 59 posts
- Ambrosiussen
- 197 posts
