Hello guys i am trying to create random colored faces for my rubik's cube, i tried using for each but that is not working can anyone help me to have 5 random color's on the faces of my rubik's cube i am attaching the file and the ref image.
Your hip file seems to be referencing an alembic file that was not included with your attachment. I made a quick test scene that creates random colors for faces, maybe you could apply this to your project.
Not sure how to send the referenced alembic file back without it being a project, but if you open the hip and load the alembic file into the first node, and make sure the group selection is correct for the faces you want colored, it should work.
But one more question can we render the same color inside houdini's red-shift render because as soon as i apply the color node that will change the color back to that assigned to the material, as the constant color doesn't appear for renders in red-shift i think.
