How to add more inputports on a vex sop with vex builder?
   3246   3   0
Hi everybody,
I'm trying to learn a bit using the vex builder and I want to read the normals of 2 different objects.
So I was hoping to build a vex with 2 different inputs.
I saw that Simon has build an orient vex operator, with 2 inputs but I could not figure out how to do this in the vex builder.
A computer is almost human - except that it does not blame its mistakes on another computer.
Tis' easy, look at the parameters for the sop vop network, it says Minimum inputs and Maximum inputs, just set them both to 2.
when you lay down a “VEX Geometry Operator” there are two parameters, Min and Max Inputs. Switch the number to however many inputs you want.
ops:
D-d-d-duh. I was looking all the time within the vex construction how to do this.
Thanks.
