Houdini Engine for 3ds Max
5390 13 1- JabbaTheNut
- 48 posts
- BrookeA
- 387 posts
- JabbaTheNut
- 48 posts
- TATstudio
- 75 posts
Hi guys.
Just installed the 17.0.352 and i can't load any Digital Asset in 3dsmax 2017 or 2019.
Does anybody here is able to make it work ?
3ds is flooding errors at launch :
thanks !
-p-
Failed to load asset <C:\Program Files\Side Effects Software\Houdini 17.0.352\engine\tools\he_boolean.hda>:
Failed to load asset <C:\Program Files\Side Effects Software\Houdini 17.0.352\engine\tools\he_calculate_occlusion.hda>:
Failed to load asset <C:\Program Files\Side Effects Software\Houdini 17.0.352\engine\tools\he_curve_instancer.hda>:
Failed to load asset <C:\Program Files\Side Effects Software\Houdini 17.0.352\engine\tools\he_delete_small_parts.hda>:
Failed to load asset <C:\Program Files\Side Effects Software\Houdini 17.0.352\engine\tools\he_polyreduce.hda>:
Failed to load asset <C:\Program Files\Side Effects Software\Houdini 17.0.352\engine\tools\he_set_pivot.hda>:
Failed to load asset <C:\Program Files\Side Effects Software\Houdini 17.0.352\engine\tools\he_surface_instancer.hda>:
thanks !
-p-
- BrookeA
- 387 posts
Those are the default shelf tools that are now included with all of the plugins. The plugin should not be failing to load those HDAs.
Can you confirm that they are not working by opening the Shelf tab and attempting to instantiate any of them as an object HDA?
Also, are you able to load any of your own HDAs?
- TATstudio
- 75 posts
- BrookeA
- 387 posts
- TATstudio
- 75 posts
- BrookeA
- 387 posts
- Poulpito
- 25 posts
I have the same problem.
And i don't able to load one of my own digital assets.
Attempted to find asset <C:/Users/poulpito/Documents/houdini17.0/otls/poulpito_lpolyreduce.hdanc> in the loaded asset store, but it could not be found.
Failed to load asset <C:/Users/poulpito/Documents/houdini17.0/otls/poulpito_ppolyreduce.hdanc>:
- BrookeA
- 387 posts
- TATstudio
- 75 posts
Indeed we wanted to try it quickly with an apprentice.
Does a core or FX licence integrate an engine licence or are they totally separated ?
edit : my bad. i've just relaunch with a FXlicence, and everything is working fine.
That's definitively the apprentice licence that is not supported.
edit2: i've just noticed something else : the engine is always launch at startup and unfortunately when rendering too (a job with no HDA).
So i will steal a licence to my FX team, even if i don't work on HDAs… i have to uninstall (or at least unload engine)
Edited by TATstudio - Oct. 11, 2018 16:13:10
- BrookeA
- 387 posts
TATstudio
I'm glad to hear that it's working with the FX license.
Yes, right now the plugin always launches at startup. This is a top RFE for me to not launch the plugin automatically by default, and also add a user option that allows you to specify whether the plugin should launch automatically. This will allow you to do renders that don't have an HDA without taking a license. I'll update this thread once the RFE is complete.
Edited by BrookeA - Oct. 12, 2018 13:58:01
- BrookeA
- 387 posts
