error
   949   0   0
When I start houdini 17, this error occurs…
Could you help me??
Error while populating shelf with shelf tool assets.
File “<stdin>”, line 1, in <module>
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\shelfutils.py”, line 183, in populateShelfFromJSON
_ensure_toolbar_dir_exists()
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\shelfutils.py”, line 279, in _ensure_toolbar_dir_exists
toolbar_dir = hou.homeHoudiniDirectory() + “/toolbar”
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hou.py”, line 67480, in homeHoudiniDirectory
return _hou.homeHoudiniDirectory(*args)
UnicodeDecodeError: ‘utf8’ codec can't decode byte 0x83 in position 24: invalid start byte
Exception in thread Thread-2:
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\threading.py”, line 808, in __bootstrap_inner
self.run()
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hou.py”, line 68171, in __threadRun
self.__run()
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\threading.py”, line 761, in run
self.__target(*self.__args, **self.__kwargs)
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hdefereval.py”, line 142, in <lambda>
thread = threading.Thread(target=lambda: function(*args, **kwargs))
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hdefereval.py”, line 162, in thread_code
it.next()
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\sas\localassets.py”, line 365, in check_for_shelf_tool_assets
asset_info_file = shelfutils._shelf_tool_assets_info_file()
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\shelfutils.py”, line 283, in _shelf_tool_assets_info_file
return hou.homeHoudiniDirectory() + “/toolbar/shelf_tool_assets.json”
Error while checking for updates
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\sas\localassets.py”, line 84, in wrapper
return decorated_function(*args, **kwargs)
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hdefereval.py”, line 194, in wrapper
_run_main_thread_worker_thread_code(it)
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hdefereval.py”, line 153, in _run_main_thread_worker_thread_code
it.next()
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\sas\localassets.py”, line 265, in check_for_asset_updates
installed_assets_info = _read_installed_assets_info()
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\sas\localassets.py”, line 657, in _read_installed_assets_info
_ensure_asset_store_dir_exists()
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\sas\localassets.py”, line 667, in _ensure_asset_store_dir_exists
if not os.path.exists(_installed_assets_info_file()):
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\sas\localassets.py”, line 731, in _installed_assets_info_file
return asset_store_dir() + “/” + _current_user_dir() + “/installed_assets.json”
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\sas\localassets.py”, line 735, in asset_store_dir
hou.homeHoudiniDirectory() + “/asset_store”)
