metaball particles. How to blend separate systems?
   2719   2   0
Hello!
It would be really good for something I am working on if I could combine some separate particle ops I have setup with different sizes and shapes using metaball Copy sops so that if I combine each Copy Sop network, they will inturn blend globally together. I can kind of achieve it with a lot of fiddling around by using convert and skin SOPs but it isn't very effecient. I was wondering if anyone has ever found a more procedural method of doing this kind of thing so that you could get separate metaball particle networks to combine with each other.
Cheers!
Frank
In my very simple test, I used a Merge SOP to combine the Copy SOPs and it seems to work. Is there something I'm missing?
It would help if you can post a simplified hip file.
Cheers!
steven
Alternatively you can use MetaGroup SOP (8.1) to group metaballs so that one group will not affect another. : )
