Mechanical joints
   1616   4   2
I tried to build a mechanism with few joints. The problem is that I don't want to control all my joints but let Houdini calculates angles and speeds when I control just a one point myself. I think the attached picture explains my situation better. So i just want to control joint 4. angle and joint 5. angle and position and let Houdini calculates how joint 1 2 3 behaves.
Looks that Bones do something like this but i never has used it. Is there some other way? Bones looks pretty complicated and not so mechanical way to do this?
Thx
Mika
Edited by mihatsu - Jan. 18, 2020 12:24:20
joint.hiplc (155.7 KB)
Doing this with bones is fairly simple, but if you have no knowledge on how to use bones, that´s another issue. You don´t need bones in this case, you could just copy a parameter from one control and paste relative to the other controls.
Angel Fucaraccio
Thanks for the answer. I need to animate movement and if i want to constant movement for the last joint, the control formulas will be very complicated for the rest of joints.
I tried the bones and i think only problem what i had, I could not figured out how to lock degrees of freedoms from joints what i dont want control myself. For example joint 2 and 3 has just one degrees of freedom.
Honestly, if you just parent those geometries and block the channels you don´t want to animate would be more than enough.
Angel Fucaraccio
Using the bones I was able to build something simple what i want. I have to say that i tried many different parenting trick but i could not create the same result than with the bones.
Joints.hiplc (578.5 KB)
