I want to mirror a point that contains the vectors N,up and side. So that a copied geometry would align correctly with these vectors. But the orientation does not get mirrored correctly. Any help is highly appreciated. please take a look at the .hip file,
Hi there! Copy SOP needs two vector which are @up and @N. third vector is implicitly calculated based on cross product between @up and @N which follows right hand rule. I used Rubber Toy to test weather these two vectors need to swap or not. As the final note @side is useless for Copy SOP!
