I´m rendering a crowd sim with Karma, and usually I create the configure layers pointing to the right locations so I can bake the usd to the disk and then render It using PDG.
The problem arises when using a sequence of .usd in the layer configure LOP. Is It possible to do this kind of workflow or do I have to bake the sequence on disk, create another single .usd with “stitch clips” and sublayer It in the stage?
Configuring file sequences on a layer
3340 8 1-
- guilhermecasagrandi
- 284 posts
- 8178 posts
- 284 posts
jsmackHi jsmack, thanks for the reply. But can´t I do that in the same LOP network, right? (so Solaris would and up creating all the necessary dependencies when generating the resulting usd file)
Sequences have to be combined with usd stitch clips or with a valueclip prim.
In my understanding, I need to do that manually, and then get the stitched usd back to LOPs, right?
- 8178 posts
guilhermecasagrandijsmackHi jsmack, thanks for the reply. But can´t I do that in the same LOP network, right? (so Solaris would and up creating all the necessary dependencies when generating the resulting usd file)
Correct, it has to be a two-step process. Mark, maybe you can clarify? Value clips are a dark art that eludes my understanding.
- 284 posts
jsmackguilhermecasagrandijsmackHi jsmack, thanks for the reply. But can´t I do that in the same LOP network, right? (so Solaris would and up creating all the necessary dependencies when generating the resulting usd file)
The (two step) process is ok for me, but It would be really usefull if we could set up this kind of info in the network (with nodes) and solaris would end up building the “correct” usd file. This “two-step” process makes the workflow not so procedural when we are getting geo from SOPs, because we must bake the sequence of usds before rendering (or adding switchers in the network) to test the render befor creating the “final” usd file.
- 8178 posts
guilhermecasagrandijsmackguilhermecasagrandijsmackHi jsmack, thanks for the reply. But can´t I do that in the same LOP network, right? (so Solaris would and up creating all the necessary dependencies when generating the resulting usd file)
It has to be two step because creating the manifest or stitching requires opening all of the frames, whereas the usd rop operates frame-by-frame.
Edited by jsmack - Oct. 29, 2020 15:58:45
- 284 posts
jsmackguilhermecasagrandijsmackguilhermecasagrandijsmackHi jsmack, thanks for the reply. But can´t I do that in the same LOP network, right? (so Solaris would and up creating all the necessary dependencies when generating the resulting usd file)
Well… so that´s It. Thanks for the answers!!
- mtucker
- 4566 posts
If you want a separate USD file per frame, value clips is the only way to combine them back into a single animated clip at composition time. I would like at some point to have the Value Clip LOP capable of doing the “stitching” step automatically as part of the USD ROP save step, but that's probably a ways off.
If you don't specifically want a separate USD file per frame, you can create a massive single USD file which is very efficient to read in (USD only loads the data for the time samples that it needs at any given time). This is much easier than working with value clips.
- 284 posts
mtucker
Sure, but a massive file is not too good when sending to a cloud farm or for working remotely through dropbox or something alike, because It has to download the entire file to make It available for the user.
