I am having a bit difficulty of figuring out a way of how material variation node is working.
I can't so far find a solution for it. Is there an simple example of hip file how it is used ? Thanks.
For example I have need to change a diffuse texture to one of the primitives assigned but rest primitives maintain the same.
Redshift Material.
Material Variation Node - Example Please ?
6177 6 0-
- cgmagic.sunhe
- 42 posts
- Enivob
- 2660 posts
Try using a primitive wrangle after the initial material assignment. Use the viewport to identify which primitive number where you want the special assignment, and write a simple if statement.
Another way is to add the candidate to a group.
Then you can process the special cases as an entire group inside the standard material node.
// Default all materials to one value. s@shop_materialpath = "/mat/ordinary_plastic"; if (@primnum==12){ //Special case here. s@shop_materialpath = "/mat/special_plastic"; }
if (@primnum==12){i@group_material_special=1;}
Edited by Enivob - Oct. 13, 2020 09:16:41
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- 8380 posts
The material variation node authors primvars used by the material to vary the appearance on the selected prim locations.
For Karma materials, the primvar must be the same as a parameter/bind in the material. Other renderers may need to use a primvar/attribute read node to bind the primvar to the shader.
- Hamilton Meathouse
- 226 posts
jsmack
Do you have any snippet examples? It's quite confusing having different vex syntaxes depending on what you're doing. For example, if I have a material variation LOP varying the diffuse_color, it creates a primvars:diffuse_color primvar.
If I Check ‘Use Snippet’ and attempt to edit this primvar with the code below, it doesn't update the value.
usd_setprimvar(0, @primpath, "diffuse_color", {0.0, 1.0, 1.0});
The help says i@primvars:foo is the syntax to use, but I'm not sure how to go about getting that to work, as the followig throws an error:
v@primvars:diffuse_color = set(0,0,1);
- 226 posts
Discovered you can avoid using the materialvariation LOP altogether if you do something like this.
float colorx = fit01(rand(@elemnum), 0.29, 0.44); float colory = fit01(rand(@elemnum), 0.185, 0.35); float colorz = fit01(rand(@elemnum), 0.13, 0.32); vector color = set(colorx, colory, colorz) *0.75; vector colorpath[]; int colorpathindex[]; append(colorpath, color); append(colorpathindex, 0); usd_addprimvar(0, @primpath, "diff_color", "color3f[]"); usd_setprimvar(0, @primpath, "diff_color", colorpath); usd_setprimvarindices(0, @primpath, "diff_color", colorpathindex);
- 226 posts
Better yet, use a color ramp!
float r=rand(@elemnum); vector color = vector(chramp('color', r)); vector colorpath[]; int colorpathindex[]; append(colorpath, color); append(colorpathindex, 0); usd_addprimvar(0, @primpath, "diff_color", "color3f[]"); usd_setprimvar(0, @primpath, "diff_color", colorpath); usd_setprimvarindices(0, @primpath, "diff_color", colorpathindex); // Viewport color //usd_addprimvar(0, @primpath, "displayColor", "color3f[]"); //usd_setprimvar(0, @primpath, "displayColor", colorpath); //usd_setprimvarindices(0, @primpath, "displayColor", colorpathindex);
Edited by Hamilton Meathouse - Nov. 7, 2020 22:02:38
- 8380 posts
Hamilton Meathouse
Isn't the point of a material variation to make it easy by avoiding writing that kind of explicit code?
The sop modes make it easy and familiar to vary the attribute values using geometry ops. Just vary the attribute in sops how you always do.
In uniform (use snippet), mode the syntax is the same as other vexpressions such as those used in popforce nodes. The tooltip says how to use it.
Set the value using a VEX snippet. The snippet should write the override value to the value variable. @ptnum is the index of the current prim/instance. You can use npoints(0) to get the total number of prims/instances to compute values for. You can use @Frame and @Time to make the value time-dependent.
E.g.: to pick a random color from the element index use:
value = random(@elemnum);
