Ok, so I've been trying to figure this out for a while with little success. Edge groups are everywhere in various different SOP nodes, and yet I have no clue really what they are? Are they point groups under the hood? I've seen that explanation offered, but that doesn't make much sense as:
1. They don't show up anywhere in the geometry spreadsheet as point groups would.
2. Theoretically I can have many different edges between two points (different primitives), so it would need to store more information.
Are there any staff folks around who could give a quick explanation of how edge groups are represented under the hood?
(My motivation here is that I'm debugging some of the AutoSeam/AutoUV GameDev tools)
What the heck is an Edge Group?
7877 8 2-
- kleptine
- 8 posts
- 9595 posts
Edge groups are defined by point pairs
You can use expandedgegroup() to get array of point pairs from existing edge group
Or setedgegroup() to add/remove point pair to a group, plus other edge functions
Since edges are technically not an element of a geometry they will not show up in spreadsheet don't have edgenums and can't hold attributes, therefore the point pair representation
Each point pair defines exactly one edge
what you mentioned in 2. houdini calls half-edges and you can also query them using vex
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- kleptine
- 8 posts
- mestela
- 1868 posts
Edges are a by-product of connecting points into prims via verticies. Hand wavey explaination here:
http://www.tokeru.com/cgwiki/index.php?title=Points_and_Verts_and_Prims#Edges_and_prims [www.tokeru.com]
- vinyvince
- 281 posts
How will you procedural creat half-edge groups to use for example in the Groupfindpath sop node"
Like from a given list of points or selected edge, pick on random half edge from each, feed that to that node?
See what i mean ?
Thanks everyone!
See what i mean ?
Thanks everyone!
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
- vinyvince
- 281 posts
If i plug a path from the shortest path, Groupfindpath doesn't seem to consider it...
- 9595 posts
vinyvincewhat do you mean by half-edge group? I don't think there is such concept
See what i mean ?
Thanks everyone!
there are edge groups, where the directionality of an edge is not implied
Group Find Path would also not use any particular directionality of an edge even if seemingly implied directly by the group string
so p0-1 would not produce different result to p1-0, at least I don't observe different behavior in any of it's modes
to create edge group procedurally you have many options for example: Group SOP, setedgegroup() VEX, Group Promote SOP
to create edge group from a polyline that aligns with some edges you can create edge group on that polyline and then Group Transfer to your geo with very small Distance Threshold so that only aligned edges transfer
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- vinyvince
- 281 posts
Thanks you Tomas, some good ideas there.
Yes i mean edge with direction. If I select edge from point, I will get a bunch, not one, or the one with a prefered direction..
For setedgegroup(), something like this?
_____
int hedge = pointhedge(0, @ptnum);
int src = hedge_srcpoint(0, hedge);
int dst = hedge_dstpoint(0, hedge);
i@hedge = hedge;
i@hedge_src = src;
i@hedge_dst = dst;
int nexthedge = hedge_next(0, hedge);
int nextsrc = hedge_srcpoint(0, nexthedge);
int nextdst = hedge_dstpoint(0, nexthedge);
i@nexthedge = nexthedge;
i@nexthedge_src = nextsrc;
i@nexthedge_dst = nextdst;
setedgegroup(0,"edgeselc",@hedge,@nexthedge,1);
_____
i@hedge = hedge;
i@hedge_src = src;
i@hedge_dst = dst;
- 9595 posts
vinyvinceno, just this
setedgegroup(0,"edgeselc", start_pt, end_pt, 1);
if you are already starting with halfedge then it's:
int src = hedge_srcpoint(0, hedge); int dst = hedge_dstpoint(0, hedge); setedgegroup(0,"edgeselc",src, dst, 1);
but as I said before, edge groups don't store direction as edge represents all equivalent half edges so potentially mixed directions
Edited by tamte - Oct. 12, 2021 13:58:23
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
