Syntax Error on placing Labs Niagara ROP node
   1203   3   1
Hi everyone,
After upgrading to Houdini Version 18.5.696 from 18.5.672 for win64, I get the following Syntax Error every time I place a "Labs Niagara ROP" node and the node has also stopped rendering an output (refer attached image)
Error running event handler:
SyntaxError: ('invalid syntax', ('labs:: Driver/niagara_rop, PythonModule', 36, 28, ' print(message, file=sys.stderr)\n'))
I am using Version 2.1 of the Houdini-Niagara Plugin for UE4.26 on Windows 10.
Any suggestion will be greatly appreciated, since I am not being able to move to the current version of Houdini.
Edited by njoshi - Sept. 26, 2021 09:20:51
Error_Labs Niagara ROP.jpg (89.1 KB)
Hi again, I managed to resolve this problem with help from SideFX Support Team.
Solution is to upgrade to SideFX Labs Build 18.5.713, which is not yet a Production Build.
Where did you get that build from. I am having the same issue
As always thank you!
Alex
Never mind I just did it inside Houdini. I am running 18.5.758 and it fixed the problem.
Alex
