krueger
This one is cleaned up a little bit, also adding the option to run over every scene view or just the active one. Adding a hotkey for the scene viewer will make it work on whichever scene view your mouse is over too.def toggleNulls(toggleAllViewers=True): import toolutils # Check to see if the nulls were toggled already. if "nullsVisible" in dir(hou.session) : visible = hou.session.nullsVisible else : visible = True hou.session.nullsVisible = visible try : desktop = hou.ui.curDesktop().name() pane = toolutils.activePane(kwargs).name() views = hou.hscript("viewls -n")[0].split("\n") if visible : toggle = "-" else : toggle = "+" # Toggle viewers if toggleAllViewers : for view in views : hou.hscript( "vieweroption -V '%snull' '%s'" % (toggle, view) ) else : # Find the viewer name for hscript. for view in views : if (desktop in view) and (".%s." % (pane) in view) : hou.hscript( "vieweroption -V '%snull' '%s'" % (toggle, view) ) # Change the stored variable. hou.session.nullsVisible = not visible except : print "No scene view open." # Toggle current viewer toggleNulls(toggleAllViewers=False) # Toggle all viewers #toggleNulls()
Hey Krueger,
would you be so kind to update your script to Houdini 19? It's not working for me. maybe because of PY3?
Thank you!
CYTE
