Is it possible to import Material X presets?
7982 9 2-
- Lyubomir Popov
- 29 posts
Hi, daft question but are there any material x presets available in H19, similar to the ones found on e.g. the principal shader? Couldn't find any when I click the cog on a mtlxstandard_surface.
I can see some examples in the official materialx repo on github, is there a way to import those into houdini?https://github.com/materialx/MaterialX/tree/main/resources/Materials/Examples/StandardSurface [github.com]
Edited by Lyubomir Popov - Dec. 5, 2021 06:26:23
- goldleaf
- 4259 posts
They aren't presets on an HDA yet, but they do ship with Houdini since they are part of MaterialX. You can find them in
The MaterialX standard test geometries and hdr lights are also in
You can use a Reference LOP to reference a specific material from a file; attached is a hip file that shows how to do this.
Hope that helps!
$HH/materialx/resources/Materials/Examples/StandardSurface/The MaterialX standard test geometries and hdr lights are also in
$HH/materialx/resources.You can use a Reference LOP to reference a specific material from a file; attached is a hip file that shows how to do this.
Hope that helps!
I'm o.d.d.
- Lyubomir Popov
- 29 posts
- Siavash Tehrani
- 735 posts
- microvswind
- 7 posts
- 8177 posts
- microvswind
- 7 posts
- 8177 posts
- microvswind
- 7 posts
- 8177 posts
microvswindjsmackHow to fix the prim referenced.microvswind
yes.and the .mtlx mateial can not works above attached by @goldeleaf.Image Not Found
The prim referenced in your scene is broken. there's nothing there to edit.
i create a empty scene and reference the .mtlx with this setteing.Image Not Found
That's correct. The same referenced prim works correctly for me. Which version of Houdini are you using?
