How can I get textures to show up in OpenGL for solaris?
5466 11 1-
- traileverse
- 369 posts
- traileverse
- 369 posts
no luck trying to get this to work, if I load up say the pig geo, the textures show in houdini gl, however, when I apply my own textures to my own models they don’t show up I have to render to see them.
Any idea what I’m doing wrong in solaris?
Edited by traileverse - Jan. 19, 2022 04:19:22
hou.f*ckatdskmaya().forever()
- malexander
- 5285 posts
HoudiniGL relies on the shader network conversion to a USD Preview shader. Our built-in shaders like the Principled shader are converted to USD Preview shaders automatically. There is limited support for MatX shader conversion as well. If you're using a completely different network, you'll need to create a USD Preview shader network manually to see the textures in GL (USD UV Texture, USD Primvar Reader, USD 2D Transform, USD Preview Shader).
- traileverse
- 369 posts
malexander
Thanks @malexander. I see what you're saying. After doing a few more test I realized that it's because the textures or UDIM based, if I load in a texture that's not UDIM it works. So, I guess my question now becomes how can I get UDIM based stuff to show up?
- 8177 posts
miccetro
put the udim token in the filename: eg
diff.<UDIM>.rat
Edited by jsmack - Jan. 19, 2022 12:49:46
- traileverse
- 369 posts
jsmackHey @jsmack thanks for reply, they were exported from substance painter with the token. See images below. Is there a specific way they should be written?miccetro
put the udim token in the filename: egdiff.<UDIM>.rat
This is how the material file loader shows it in houdini.
Edited by traileverse - Jan. 19, 2022 13:07:56
- 8177 posts
miccetro
written, no. The token goes in the file name when read.
miccetro
Looks good. Is that what the asset path shows when inspecting the properties in the scene graph details view?
- traileverse
- 369 posts
jsmackImage shows what I'm seeing in the details view. And it renders in Karma as well, but won't show up in houdini glmiccetro
written, no. The token goes in the file name when read.miccetro
- 8177 posts
- traileverse
- 369 posts
jsmacklol no it's a SSD but I have it as B drive; yeh don't know why I can't get it to work.miccetro
Everything looks good there, I don't know what else it could be.
B:\? is it really loading off of a floppy drive?
- traileverse
- 369 posts
jsmackI renamed the files (as seen here in image compared to previous image) and it now works! So by removing the color space (-ACEScg) part of the string the file works. Not sure what the issue is there, but maybe that can help you debug the problem. Also, if the filename doesn't have the <UDIM> token, it works with the color space part still in the filename.miccetro
Edited by traileverse - Jan. 19, 2022 19:37:04
- 8177 posts
miccetro
The spaces in the name might have been confusing the udim globbing. I try to avoid the extra long names in the aces config that contain spaces and extra characters. The config has 'short' versions of most of the spaces as aliases. 'ACES - ACEScg' is simply 'acescg' in the reference config.
