Geometry to Milk
5682 9 0-
- O_Speiser
- 12 posts
I am trying to achieve a similar effect as seen in the attached jpg file. My arm gemoetry is animated.
Last time I did splahes, I prepared the source points with various noises and some modeling to achieve an interesting starting shape and velocity values. Here, the difficulty is to preserve most of the shape and only have certain areas work.
Maybe it doesnt need a sim at all. Extrusion, scattering of spheres to get tendril shapes and vdb smoothing. After that, bring in movement through either noise on the tendrils or even vellum. Ideas?
Thanks a lot,
Oliver
Thanks a lot,
Oliver
- Enivob
- 2658 posts
Check out the Caramel Blast tutorial. It might get you the tendril look.
https://www.sidefx.com/tutorials/caramel-blast-houdini-tutorial-project-files-including-hip/ [www.sidefx.com]
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- O_Speiser
- 12 posts
- Hatchery
- 141 posts
I did something when playing with particles - https://www.instagram.com/p/CJibNLDH-O4/ [www.instagram.com]
Adapted from this:
https://www.youtube.com/watch?v=4mPHh-WzGZ4&list=PL0fCQcmH9FnOrcq4nbuUWSI8j_2NuAVpv&index=9 [www.youtube.com]
You might be able to adapt somthing with out having to resort to flip which can get a bit of a rabbit hole of settings.
Adapted from this:
Love Houdini
- Konstantin Magnus
- 719 posts
You could also attach some curl noise curves, but I guess it won't look too convincing when animated.
Edited by Konstantin Magnus - Feb. 1, 2022 13:57:25
- O_Speiser
- 12 posts
- Konstantin Magnus
- 719 posts
Hi Oliver,
sure, here is a breakdown:
- Cut the arm, polyfill the hole, scatter points.
- Trail curves with curl noise and resample.
- Replicate random points from the curves.
- Remap curveu to pscale, convert to VDB from points.
- VDB reshape fluid and combine VDBs.
- Blend VDBs using smooth minimum [www.iquilezles.org].
- O_Speiser
- 12 posts
Hello again,
I think I managed to more or less implement your workflow, but my results are much worse than what you showed here. I guess I am just lacking the experience.
I came to a point where I feel that a sculpting workflow maybe wouldnt be so bad in this particular case, but I have even less experience with sculpting.
Then I started playing again with FLIP and I think it's still the way to go, even though it takes a lot of patience to find appropriate values.
I am happy to collect more tips, so if anyone has more ideas or knows how to further improve those mentioned in this post, I would be very happy and thankful.
- Konstantin Magnus
- 719 posts
Anak_Sulap
Hi Anak,
I share the (cleaned-up) file now:
https://procegen.konstantinmagnus.de/liquifying-geometry [procegen.konstantinmagnus.de]
- Konstantin Magnus
- 719 posts
I've recorded a tutorial on this a while back:
https://www.youtube.com/watch?v=V_m17E8xu90 [www.youtube.com]
