I'd appreciate some help regarding this.
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (7): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.changeactivename" not found
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (8): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.setname" not found
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (18): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.hideselected" not found
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (19): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.hideunselected" not found
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (20): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.unhideall" not found
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (22): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.resample" not found
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (23): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.redistributepoints" not found
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (24): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.add_segment" not found
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (25): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.remove_segment" not found
ERROR: C:/Users/Admin/AppData/Local/Temp/houdini_temp/hfs20152-13.tmp (27): Hotkey symbol "h.pane.gview.state.sop.sidefx_groom.delete_key" not found
