Trying to create trails through particles
   4777   6   0
I am trying to create curvy trails through particles. However, I am getting straight lines when I use trails SOP. What should I do?
trails question.hip (675.6 KB)
Revisit the tutorial, specifically the section on setting up the trail node.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
in the trailSop change the result type to "preserve original". the addSop connects the points later by id
sanostol
Thanks a ton! That did it! However, the trails don't come out to be smooth. I used a resample SOP and that didn't solve it.
Then I used smooth SOP and it helped. However, it appears as if smooth SOP uses more memory than resample and I feel there's a way to create smooth trails without using either of those but I don't know how.
Moreover, I get these warnings in my DOP network. Why are they coming? I didn't change the source geometry at all.
Edited by proceduralist - Oct. 18, 2022 11:38:22
Enivob
Looks really cool! Actually the tutorial only covered using particles and collisions. It doesn't mention anything on trails. I'll check out other tutorials on trails once again. How did you change the colour of the trails on the ground to change with time?
Here's my method for trails with fixes for issues similar to yours. I think its fairly robust, and not too cpu intensive (the trail sop can get really laggy with high values):
https://www.tokeru.com/cgwiki/index.php?title=PopsSplitAvoid#Making_trails_with_pop_replicate [www.tokeru.com]
mestela
Thanks Matt. Tried the pop replicate method. Works very well!
trails question_re.hip (789.2 KB)
