In Karma, How do i get an ambient occlusion render pass?
8618 10 2-
- Beka
- 42 posts
- 8184 posts
On the Karma Render Settings node, enable "Simplified Shading" to switch to a global ambient occlusion mode. Note that Display color still tints the scene, so you might need to block the attribute on the geometry to get a gray render if the attribute is present.
Edit:
It doesn't seem to enable AO for XPU though, instead it renders a simple version of the scene without shaders and headlight only.
Edit:
Edited by jsmack - Oct. 29, 2022 17:36:16
- Beka
- 42 posts
jsmackThank you. Yeah, it looks like it might work, but Karma defenetely needs more better way of AO
Edit:
- 8184 posts
- Beka
- 42 posts
- 8184 posts
- papahh
jsmackThis sound you should avoid write answer here.bekajsmackYes. It is a super global and I need more control. For example, I need AO only between objects and a ground and not AO of self produced ground.
Better than checking a box?
That sounds like you need to write a custom shader.
Edited by papahh - May 23, 2024 09:43:44
- vopsop
- 19 posts
- Heileif
- 291 posts
vopsopjsmackWOW, still an issuebekajsmackYes. It is a super global and I need more control. For example, I need AO only between objects and a ground and not AO of self produced ground.
This is in the changelog.
20.5.305
XPU: adds support for AO AOV
Edited by Heileif - July 8, 2025 09:14:21
- mrtn
- 3 posts
have a look here and analyze the hda. This should be tweakable to do what you need.
https://senlegio.gumroad.com/l/ss_clay_material_override [senlegio.gumroad.com]
Edited by mrtn - July 8, 2025 11:30:40
- Mirko Jankovic
- 279 posts
HeileifThere is AO AOV now but zero control. Falloff, distance.... anything. Any ideas if we can do any control with that at all?vopsopjsmackWOW, still an issuebekajsmackYes. It is a super global and I need more control. For example, I need AO only between objects and a ground and not AO of self produced ground.
20.5.305
