I'm trying to "fuse" together boolean pieces with the same name attribute and can't seem to get the last step. Basically, I want to reduce the smaller pieces by combining them with their neighbor (based on attribute transfer distance, in this case).
In the file provided, I have fracture a geo with boolean, grouped the result into "big" and "small" groups, transfered the name attribute from the large pieces onto the smaller ones...and then I'm stuck. If I use an exploded view, the smaller pieces are "fused" to the larger ones, but once I send the geo into a sim, the pieces are not seen as one chunk.
Note: I realize this can be done with an rbdcluster node, but I was trying to find another way on my own.
Thanks for any help!
Fuse/combine Boolean Pieces with same name attribute
710 1 0- TheDude123
- 65 posts
- Benyee
- 56 posts
