Using a Trigger CHOP to drive a Constraint Blend not working
1480 7 1- mike2000
- 12 posts
Hi. I am trying to use the output from a Trigger (CHOP)operator to drive the 'blend' parameter of a Constraint Simple Blend operator. The Trigger is configured to produce a linear transition from 0-1 over N seconds when 'triggered'. The blend is 'blending' between two channels and used to adjust a polywire's thickness. Individually, both components work fine. The blend effect works when manually adjusting the blend parameter or using a CHOP("") to reference a Constant operator. I have tried both placing a chop("") on the blend parameter referencing the trigger and exporting the trigger channel to the blend parameter but neither approach works. When connected with the timeline running (play), the trigger's output is sporadic. Any help is greatly appreciated.
- cncverkstad
- 122 posts
- mike2000
- 12 posts
- cncverkstad
- 122 posts
- mike2000
- 12 posts
- cncverkstad
- 122 posts
- cncverkstad
- 122 posts
- mike2000
- 12 posts
