Hello
I was trying to find a method to open the most recent file with a hotkey, I didn't find it of course.
but thought about something like a little window populated with all other recent files, sorted out from top to bottom and then I can choose one to open.
I'll be grateful to let me know if there is such a thing possible with Python in Houdini.
Open Recent File, Python method
4411 11 1-
- MirHadi
- 147 posts
- SWest
- 313 posts
Is this not already implemented?
It is like one click on the file menu and some movement. I use this regularily.
Having a hotkey is still a click and then you move the mouse to choose. So it does not seem to improve things much.
Unless you have hidden your menu that is.
Are you sure you need it?
It should be possible to do if really needed.
- animatrix_
- 5091 posts
MirHadi
Hello
Hi, there is no such thing built-in. But you can implement it yourself:
def getRecentHipFiles(): userdir = hou.getenv('HOUDINI_USER_PREF_DIR') file = os.path.join(userdir, "file.history") validfiles = [] with open(file) as f: lines = f.readlines() for line in lines: newline = line.strip() if newline == "}": break; if newline != "{" and newline != "HIP": if os.path.exists(newline): validfiles.append(newline) validfiles.reverse() return validfiles
I talk about this exact issue in my GamesCom Asia 2022 talk. It's the only thing I had to create to completely replace the main menu bar. Other actions can be invoked via hotkeys. But if you want to have a popup window populated with recent files with the ability to load them using a hotkey directly from the window using 1-9 keys, you will have to implement this in Qt.
- SWest
- 313 posts
While testing the python keyboard modules I did a mistake and had to redo this quickly. Feel free to update and improve. I'm out of time for now.
import os def getRecentHipFiles(): userdir = hou.getenv('HOUDINI_USER_PREF_DIR') file = os.path.join(userdir, "file.history") validfiles = [] with open(file) as f: lines = f.readlines() for line in lines: newline = line.strip() if newline == "}": break; if newline != "{" and newline != "HIP": if os.path.exists(newline): validfiles.append(newline) validfiles.reverse() return validfiles def createFilesDict(input_list): '''Used to create a dict with files from a list of files with absolute paths.''' files_dict = {} for item in input_list: basename = os.path.basename(item) files_dict[basename] = item return files_dict def recentFilesWindow(): '''Show recent files''' files_list = getRecentHipFiles() files_dict = createFilesDict(files_list) enumerate_list = [] title = 'Recent Files' message = '' c = 1 input_labels = () for k,v in files_dict.items(): input_labels += (str(c)+' '+k,) enumerate_list.append(str(c)) c += 1 initial_contents = () for v in files_dict.values(): initial_contents += (v,) help = """ Help for choosing: Please click on the button matching the number of intended file. """ buttons = (enumerate_list) severity = hou.severityType.Message choice, user_contents = hou.ui.readMultiInput(message=message, input_labels=input_labels, password_input_indices=(), buttons=buttons, severity=severity, default_choice=0, close_choice=-1, help=help, title=title, initial_contents=initial_contents) recentFilesWindow()
- MirHadi
- 147 posts
- SWest
- 313 posts
Great, here’s some thoughts just not to forget them.
Required:
The dict function need to be made robust so if there is a key collision the second key name get some number appended.
Alternatively the key itself could just be the number. What would you prefer?
Not essential:
The user content (editable part) could be used so that if a recent file is not specified you could just adjust the string. For example you want version 06 but you have only from version 07 and up. Well just change and open.
However, RFE:s are probably best to do after using the tool for a while.
Anyone can complete this I don’t mind.
Cheers!
Required:
Not essential:
Cheers!
- SWest
- 313 posts
This tool will open a window presenting recently opened HIP files. Click on a corresponding number to choose.
To install:
Will this work?
Do you have any BUG-reports or requests?
Anyone may update this tool as needed.
To install:
- Create a "New Tool" in any Shelf that you prefer
- Name it "Recent HIP".
- Copy and paste the below Python into the Script part.
- Add a Global Hotkey using the Shelf graphical interface for that tool (for example "Ctrl+Shift+O").
Will this work?
import os def getRecentHipFiles(): userdir = hou.getenv('HOUDINI_USER_PREF_DIR') file = os.path.join(userdir, "file.history") validfiles = [] with open(file) as f: lines = f.readlines() for line in lines: newline = line.strip() if newline == "}": break; if newline != "{" and newline != "HIP": if os.path.exists(newline): validfiles.append(newline) validfiles.reverse() return validfiles def createFilesDict(input_list): '''Used to create a dict with files from a list of files with absolute paths.''' files_dict = {} key_collision = False for item in input_list: c = 1 basename = os.path.basename(item) basename_copy = basename # fix key collisions (no duplicates) while basename_copy in files_dict.keys(): key_collision = True basename_copy = basename + ' ' + str(c) c += 1 if key_collision: basename = basename_copy files_dict[basename] = item return files_dict def recentFilesWindow(): '''Show recent files. User may edit file paths of recent files. User can click on a number corresponding to a list of recent files.''' files_list = getRecentHipFiles() files_dict = createFilesDict(files_list) enumerate_list = [] enumerate_list.append('Cancel') title = 'Open a Recent File' message = ''' Please click on the button matching the number of intended file to open it.''' c = 1 input_labels = () for k,v in files_dict.items(): input_labels += (str(c)+' '+k,) enumerate_list.append(str(c)) c += 1 initial_contents = () for v in files_dict.values(): initial_contents += (v,) help = """ You may edit a path manually if you wish. """ buttons = (enumerate_list) severity = hou.severityType.Message choice_int, user_contents = hou.ui.readMultiInput(message=message, input_labels=input_labels, password_input_indices=(), buttons=buttons, severity=severity, default_choice=0, close_choice=-1, help=help, title=title, initial_contents=initial_contents) # check if file exist: open or feedback file_name = user_contents[choice_int-1] if (os.path.isfile(file_name) and choice_int != 0 ): print(file_name) hou.hipFile.load(file_name, suppress_save_prompt=False, ignore_load_warnings=False) if not (os.path.isfile(file_name)): message = file_name+' does not exist.' temp = hou.ui.displayMessage('Input error: '+message, \ title='Notification', buttons=('OK',)) recentFilesWindow()
Edited by SWest - Oct. 15, 2023 09:45:20
- anon_user_95266836
- 64 posts
My version
import os def getRecentHipFiles(): userdir = hou.getenv('HOUDINI_USER_PREF_DIR') file = os.path.join(userdir, "file.history") validfiles = [] with open(file) as f: lines = f.readlines() for line in lines: newline = line.strip() if newline == "}": break; if newline != "{" and newline != "HIP": if os.path.exists(newline): validfiles.append(newline) validfiles.reverse() return validfiles files = getRecentHipFiles() if files: ids = hou.ui.selectFromList(files, default_choices=(0,), exclusive=True, title="Open Recent Scene", column_header="Recent Scenes", clear_on_cancel=True, width=hou.ui.scaledSize(700)) if ids: hou.hipFile.load(files[ids[0]])
- SWest
- 313 posts
- 64 posts
And a more elegant way of selection from a Qt menu
import os from hutil.Qt.QtWidgets import QMenu from hutil.Qt.QtGui import QCursor from hutil.Qt.QtCore import QPoint def getRecentHipFiles(): userdir = hou.getenv('HOUDINI_USER_PREF_DIR') file = os.path.join(userdir, "file.history") validfiles = [] with open(file) as f: lines = f.readlines() for line in lines: newline = line.strip() if newline == "}": break; if newline != "{" and newline != "HIP": if os.path.exists(newline): validfiles.append(newline) validfiles.reverse() return validfiles files = getRecentHipFiles() if files: menu = QMenu(hou.qt.mainWindow()) menu.triggered.connect(lambda action: hou.hipFile.load(action.text())) [ menu.addAction(f) for f in files ] menu.setActiveAction(menu.actions()[0]) menu.exec_(QCursor.pos() - QPoint(hou.ui.scaledSize(8), hou.ui.scaledSize(8)))
Edited by anon_user_95266836 - Oct. 15, 2023 11:11:46
- SWest
- 313 posts
Alexey_Vanzhula
The QT method I would say is clearly the most minimalistic approach. The text also look like it belongs to the interface rather than having some different style. It is also a fast two press/click approach. Nice!
Edited by SWest - Oct. 15, 2023 16:31:08
- MirHadi
- 147 posts
