How do i control the number of repeat tiling in mtlx
   2139   4   0
i have simple question
how do i control the number of repeat tiling in mtlx?
thanks ,nir
Edited by habernir - Dec. 17, 2023 08:41:40
Use a mtlxTiledImage node and increase the Realworldsize to introduce more copies.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
thanks for your answer but the mtlxTiledImage its just tiled rate in uv direction and the Realworldsize just control the size of the single square ( am i wrong?)
this is the result
i want to control the number of repetition in the u direction
in mtlxImage i make
U Address Mode: periodic
V Address Mode:Constant
and the result its repeating along the u direction like this
but i want to control the number of repeat in the u direction (i want for example do make 2,3 or 4 lines....)
thanks
Edited by habernir - Dec. 17, 2023 10:58:28
Screenshot 2023-12-17 155127.png (1.6 MB)
Screenshot 2023-12-17 155318.png (1.7 MB)
habernir
There is no built in mechanism for this. You'll have to get out the math and do it yourself. The clamp node can be used to clamp the scaled u and v values to the desire maximum
jsmack
habernir
thanks. i already know about clamp but i forgot that there is mtlx clamp and thats solved my problem in mtlx
Edited by habernir - Dec. 17, 2023 15:47:49
