Display Icons in HDA Help Page
   2834   4   2
Looking through this page as I document an HDA:
https://www.sidefx.com/docs/houdini/help/format.html#icons [www.sidefx.com]
I have some buttons in my HDA that are represented only as icons, loaded from the standard set of icons (hicon:/) that ships with Houdini. I'd like to add these to the parameters description of my HDA's Help page, but I am struggling with the syntax. My wiki markup-fu is failing me. The page linked above shows examples of icons from other nodes (e.g. Icon:SOP/copy, but I'd like to pull my icon from the hicon:/ location instead.
Anyone know the syntax for that?
Edited by Tim Crowson - Dec. 15, 2023 13:36:19
- Tim Crowson
Technical/CG Supervisor
Hey.
Try this:
[Smallicon:BUTTONS/cook]
I'm not sure where I got it from. I think I had to dig it up in the Houdini install.
Edited by Honza Topinka - Dec. 21, 2023 04:30:58
I use this template for years:
= Attribute Gradient =
#type: node
#context: sop
#internal: attribGradient
#icon: opdef:.?icon64.svg
"""Computes the gradient of a scalar attribute using connectivity or proximity."""
@parameters
Group:
    #id: group
    Subset of geometry to use.
Group Type:
    #id: grouptype
    The type of entities in the group.
Attribute:
    #id: attribute
    Name of the input attribute.
New Attribute:
    #id: new
    Name of the new attribute that will store the gradient.
Method:
    #id: method
    The method used to compute the gradient.
    Connectivity:
        Uses edge connectivity to compute the gradient.
    Point Cloud:
        Uses point proximity to compute the gradient.
Neighbouring:
    #id: neighbouring
    The type of neighbouring to use.
    By Edges:
        Uses the edge neighbours of each point when gathering their point neighbours.
    By Primitives:
        Uses the primitive neighbours of each point when gathering their point neighbours.
Depth:
    #id: depth
    Number of edges/primitives away from the points.
Radius:
    #id: r
    The radius of the search.
Max Points:
    #id: maxpts
    The maximum number of points queried within the search radius.
Use Radius Attribute:
    #id: useradius
    Uses a per-point radius attribute.
Radius Attribute:
    #id: radius
    Per-point radius attribute that expands the search radius.
Radius Scale:
    #id: rscale
    Multiplier for the radius attribute.
Invert:
    #id: invert
    Negates the direction of the gradient vector.
Show Guide:
    #id: guide
    Shows the gradient vectors in the viewport.
Guide Scale:
    #id: guidescale
    The scale of the guide geometry.
Honza Topinka
Hey.
Try this:
Thanks! This did the trick... I almost had it, just had to replace the underscore with a slash...
[Smallicon:BUTTONS_cook]--> [Smallicon:BUTTONS/cook]
- Tim Crowson
Can we use any file type? I tried #icon: opdef:.?icon64.pngbut its not picking up the image.
