Is there a procedural way to smooth capture weights?
   2484   4   1
I'd like to smooth out the capture weights for skeletal deformation. So far I only found this:
It works, but Joint Capture Paint is a non-procedural node. And it can only smooth out all the weights at once, or interactively with viewport brush. How could I, for example, smooth out weights for a single joint, or all the points in a certain group?
Edited by kodra - Dec. 27, 2023 23:37:25
Screenshot 2023-12-28 123401.png (65.5 KB)
Not an exact answer but using deltamush sort of has the same effect in the end.
And I vaguely remember something with unpacking the capture attributes, a blur attrib node to smooth things after which you pack it again. it will only blur the current weighs assignments and not "spill" over into new joints/bones.
More code, less clicks.
you can use Smooth SOP
- Attributes: boneCapture
- Filter Quality: 1 (seems to give smoother results)
Edited by tamte - Dec. 30, 2023 03:33:15
CG Supervisor
Framestore, NY
tamte
It actually works! Kinda to my surprise, as boneCapture seems to be a complex structure, not just a simple attribute.
kodra
tamte
Yes, some nodes luckily deal with capture attribute
Another one that works and you may find useful is Attribute Transfer SOP, which in theory can also be used for smoothing even though only proximity based one
CG Supervisor
Framestore, NY
