Particle emitter stops working when in RBD Bullet Solver
   1628   4   1
Hi!
I have a setup where I want to have a stream of rocks flowing through a pipe. I used $F in jitter seed parameter of a points from volume node so I get between 0 and 5 points on each frame. Then into popnet and copy to points to have rocks birthing randomly. That all works fine, but when I put into RBD bullet solver so the rocks can collide with the pipe, I don't see any rocks at all.
This setup worked great (including the RBD solver) when I had a set number of rocks birthed only on the 1st frame. They went through the pipe just fine.
What am I doing wrong here? Hipnc file attached.
thanks,
Dan
pipe with rocks.hipnc (1.0 MB)
-Dan Huiting
you don't need to use pop solver, just check Emit RBDs on Bullet Solver directly
pipe_with_rocks.fix.hipnc (1007.8 KB)
CG Supervisor
Framestore, NY
Hi Tomas!
Thanks so much! That is super helpful. It works now, yay!
I am wondering one other thing. I used a clip node at the end of the pipe to get rid of the rocks flying around after they leave the pipe, but at frame 233 there's a random rock that seems to come out of nowhere past where the clip point is. Is there a more elegant way to get rid of points after they exit the tube?
Screenshot and updated project attached.
thanks,
Dan
rando rock.png (309.7 KB)
pipe_with_rocks.fix.clip.hipnc (953.5 KB)
-Dan Huiting
instead of clipping post sim you can delete pieces during sim
dive inside of bulletsolver1
insert POP Kill node and type this into Rule VEXpression:
dead = v@P.x > 2.95;
Edited by tamte - March 4, 2024 10:40:47
CG Supervisor
Framestore, NY
Thanks Tomas! That worked great. Problem solved.
thanks,
Dan
-Dan Huiting
