Is there any way to convert polygon to nurbs curve without a sharp corner?
   8147   16   4
see attached,
use carve before convert.
nurbscurve_fix.hiplc (64.9 KB)
cpb
see attached,
Thank you for help. It solve the problem partially. But it's hard to give me a perfect shape, like a perfect circle.
If there is a way to give result like the picture below. That'd be best.
Edited by bao007fei - March 9, 2019 14:27:00
try the fit sop…with interpolation
Edited by Jim Rutherford - March 9, 2019 21:00:25
1. Drop a “Circle” node.
2. Change the “Primitive Type” to “NURBS Curve”.
3. ???
4. PROFIT!
Just a simple example…
The point is I want to figure how to to convert a polygon to nurbs curve and keep the shape clean. No sharp corner and point variation. Just use the polygon points to generate a smooth, clean and closed nurbs curve.
Thank you all but the solutions above aren't robust enough.
fit doesn't work?
Jim Rutherford
fit doesn't work?
It give the shape but bigger than I need.
I actually want to keep the points stay at their origin and get blue nurbs.
okay…I think you can do what you want with a python sop using createNurbsCurve with the point positions…
Jim Rutherford
I'll check that. Thanks for the clue.
another way would be to make a nurb circle with same number of points and wire your polygon into an attributeCopy sop and match the P
Jim Rutherford
Wow. This is what I need. Simple and clever.Thank you very much.
Edited by bao007fei - March 11, 2019 04:34:41
I go with the attribute copy method also,
But what is happening here under the hood? Is there nothing to detect, debug or solve such a thing? Why is one point completely near the curve and while all the other points keep a distance from the curve? By what is that controlled? By something the user could acces? or something hidden?
It seems so random and inexplicable, uncontrollable, like a bug or something.
Edited by OdFotan - May 4, 2021 08:55:41
Screenshot 2021-05-04 at 14.41.47.jpeg (148.8 KB)
Screenshot 2021-05-04 at 14.37.46.jpeg (153.0 KB)
in the original file append Basis SOP, change U Parametrization to Uniform and you should get expected result
CG Supervisor
Framestore, NY
Thanks, let me try that..
edit: it doesn't do it:
Edited by OdFotan - May 4, 2021 16:48:40
huh.hiplc (93.4 KB)
Sorry for necroposting, just ran into a similar problem. It's easily solved with unclamp option in ends:sop, and uniform parametrization in basis:sop.
yes, it is decided by an intrinsic attribut called "closed" on prim.
use the function setprimintrisic(0,'closed',0,1) to manipulate it.
