Hi!
I need to find the min and max value of a displacement texture. I was using a Detail Wrangle to go over each pixel but its a bit slow with 4K textures. Is there a trick to getting the min/max values faster (with less calculations)?
-Olivier
VEX: Get Min/Max Values of a Texture (the Fastest Way?)
1088 4 0-
- olivierth
- 1177 posts
- animatrix_
- 5100 posts
The fastest method is likely to load the texture into COPs and use the Volume Reduce SOP. You have to split the volume into scalar volumes using the Volume Vector Split SOP as Volume Reduce SOP doesn't support collated volumes.
- 9379 posts
- olivierth
- 1177 posts
- 9379 posts
