Rendering a scene that tops out my ram (32gb on both machines) so it needs some swap to pull it off. On windows 11 it worked fine by increasing the swap, on ubuntu it keeps on crashing with the same amount of swap.
The amount of swap seems a bit high too. On windows it worked for the first 30 frames with 48gb swap and had to up it to 72gb to keep going.
Might be some tweaking of how the swap gets used in Ubuntu I'm missing?..
The swap only gets used in starting the render once it gets going its fully on ram and running full tilt.
Swap File Crash Ubuntu
725 5 0-
- dany27227
- 32 posts
- johnmather
- 640 posts
Linux has a "swappiness" value that tells the OS how aggressively it should utilize the swap space. This value is between 0 and 200, where 0 indicates minor swapping, and 200 means "use the swap space at all costs".
You can check the current value by running:
You can change the value by running:
You can make the value permanent by adding
Note that larger numbers can negatively affect performance, so choosing the right number is a bit of a balancing act. This site has a good explanation: https://phoenixnap.com/kb/swappiness [phoenixnap.com]
Try increasing the number and see if it makes any difference.
cat /proc/sys/vm/swappiness
sudo sysctl vm.swappiness={value}
vm.swappiness = {value}
to /etc/sysctl.conf
Edited by johnmather - July 15, 2025 10:30:15
- dany27227
- 32 posts
- dany27227
- 32 posts
- dany27227
- 32 posts
Found this post with two possible explanations:
https://askubuntu.com/questions/1487392/why-does-memory-heavy-processes-lead-to-system-crashes-when-swap-is-available [askubuntu.com]
The badblocks theory lines up because I wasn't getting the crash on my windows machine that had the same 32gb ram and big swap config. The windows machine had the swap on a newer m.2 drive.
- dany27227
- 32 posts
