Am I correct in assuming because there is no XPU on macos there is also no bake gsplat node?
Documentation Link [www.sidefx.com]
Bake gsplat node on macos
1156 2 0-
- chf
- 203 posts
- brians
- 611 posts
chf
No, not correct
- XPU does run on macOS, but it only uses the CPU device (ie will not make use of the GPU), meaning it will run very slowly.
- The BakeGSplat node is a SOP, so runs outside of XPU. In fact the results of the BakeGSplat SOP will feed both XPU and the Vulcan viewport.
- Because XPU is only running on the CPU on macOS, expect gaussian splats to run very slowly in XPU on mac. But the Vulcan viewport should run fine.
Edited by brians - Sept. 3, 2025 04:01:11
- malexander
- 5333 posts
