I may be doing something incorrectly but when I try to save a recipe as a tool on the Custom File Path and select a directory I know for certain is on HOUDINI_PATH the dialog says 'Save directory is not on the Houdini path, this preset will not be installed automatically on startup. And, of course, the tool is not available on the next Houdini start.
If I save using the 'User Preferences' option, which is not on the HOUDINI_PATH, no warning and the tool is available after a Houdini restart.
I'd like to save my recipes in various directories in my file system, for organizational purposes. I would, of course, include these directories on HOUDINI_PATH.
Am I missing something?
MacOS Sonoma.
Thanks,
Greg
Saving Recipies to Directory on HOUDINI_PATH Not Working
6205 16 4-
- GregBollella
- 58 posts
- mabelzile
- 450 posts
- GregBollella
- 58 posts
- folpatte
- 10 posts
- mabelzile
- 450 posts
folpatteTry installing your recipe file with a package to load your recipes in Houdini.
That is something that I would be interested in too. Being able to save recipies in a custom directory, and set a custom path to load them, so that they would be installed on startup, just to be able to store recipies for upcoming versions of Houdini.
Would be great !
E.g.
{ "hpath": "/var/tmp/myrecipes" }
The recipe file must be located here
/var/tmp/myrecipes/otls/myrecipe.hda
In the next 20.5 production build, you'll be able to set a custom recipe path with HOUDINI_CUSTOM_RECIPE_DIR.
E.g.
{ "hpath": "/var/tmp/myrecipes", "env" : [ {"HOUDINI_CUSTOM_RECIPE_DIR": "/var/tmp/myrecipes"}, {"HOUDINI_CUSTOM_RECIPE_LIBRARY": "myrecipe"} ] }
The recipe dialogs will lock their save directory location to HOUDINI_CUSTOM_RECIPE_DIR
- Rifs
- 3 posts
mabelzile
"env" : [
how do you set it up, pretty boob here. Do you mind giving more detail like what file goes where?
and also what if I want to save on D: drive (D/lib/houdini)?
- mabelzile
- 450 posts
Rifsmabelzile
"env" : [
The above JSON package file setups a custom recipe folder "/var/tmp/myrecipes" with the recipe file name "myrecipe" as a custom library name, so all recipes saved with the recipe dialogs will be located in "/var/tmp/myrecipes/otls/myrecipe.hda". On startup Houdini will load the package along with "myrecipe.hda". The package file should go under your <user folder>/packages, In your case just swap "/var/tmp/myrecipes" with "D:/lib/houdini" as the custom recipe dir.
Check out the documentation for more details about these env vars and packages.
- Mark Wallman
- 741 posts
Hi. Just to check is hpath the same as HOUDINI_PATH and if not what are the differences?
Also I noticed your hpath comes before env. Does it have to be like this? Im currently adding it to our json file which right now looks like this (thanks for any advice in advance!!
"env":[
"HOUDINI_ACCESS_METHOD" : "3"
"PDG_USE_PDGNET" : "0"
"HOUDINI_NO_LEGACY_MENUS" : "1"
"HOUDINI_DSO_ERROR": "0"
"HOUDINI_PACKAGE_VERBOSE": "1"
"HOUDINI_BUFFEREDSAVE": "1"
"HOUDINI_PATH": "P:/all_work/shared/scripts/Houdini/apexgraph"
"HOUDINI_PATH": "C:/Docs/houdini20.0/lighter-main"
"HOUDINI_OTLSCAN_PATH" : "C:/Docs/houdini20.0/olts"
"HOUDINI_OTLSCAN_PATH" : "P:/all_work/shared/scripts/Houdini/otls"
"HOUDINI_TOOLBAR_PATH": "C:/Docs/houdini20.0/toolbar"
"HOUDINI_DESKTOP_DIR": "C:/Docs/houdini20.0/desktop"
"HOUDINI_USER_PREF_DIR": "C:/Docs/shared_content"
"KARMA_XPU_MAX_TEXTURE_RES" : "8192"
"KARMA_XPU_MAX_UDIM_U" : "90"
"KARMA_XPU_MAX_UDIM_V" : "90"
"hpath": "P:/all_work/shared/scripts/Houdini/recipes",
{"HOUDINI_CUSTOM_RECIPE_DIR": "P:/all_work/shared/scripts/Houdini/recipes"}, {"HOUDINI_CUSTOM_RECIPE_LIBRARY": "customRecipes"}
"env":[
Edited by Mark Wallman - Sept. 6, 2024 11:47:08
- mabelzile
- 450 posts
- Mark Wallman
- 741 posts
- Thomas M
- 3 posts
Hi everyone,
I’m trying to load my Houdini recipes from a custom Google Drive folder, but I can’t tell if Houdini is recognizing the setup. The Mops.json file in the packages folder is working fine; it’s just this custom directory that’s giving me trouble.
Here’s what I’m using:
json
Copy code
"HOUDINI_PATH": "j:/My Drive/Houdini_Recipes",
"env": [
{"HOUDINI_CUSTOM_RECIPE_DIR": "j:/My Drive/Houdini_Recipes"},
I’ve tried adjusting to forward slashes, but still no luck. Does anyone know if HOUDINI_CUSTOM_RECIPE_DIR is valid for loading recipes, or have advice on getting custom paths to work?
json
Copy code
"env": [
- mabelzile
- 450 posts
Thomas MWhat is the issue exactly ?
Hi everyone,
json
Copy code
"env": [
j:/My Drive/Houdini_Recipes/otls/myrecipe.hda should be listed in the Recipe Manager unless the package is not loading for some reason.
Does j:/My Drive/Houdini_Recipes/otls/myrecipe.hda exist on disk ?
- Elliot Stronge
- 18 posts
The custom file path option for saving recipes seems absolutely broken. I tried saving a recipe to a network location (i.e. "//something/goes/here/recipe.hda") and for some scuffed reason it appended "C:\User\username" to the front. When I try manually type the location I cannot delete the "C:\" part without it automatically refilling "C:\User\username" again so I can never fully clear the field. What on earth is up with that? Such incredibly frustrating design.
What is the intended design here? I just want to save a recipe to a common location (i.e. with HOUDINI_PATH or HOUDINI_OTLSCAN_PATH) so other artists can use them.
Edited by Elliot Stronge - Jan. 15, 2025 21:58:24
- mabelzile
- 450 posts
Elliot Stronge
This is an obvious bug, the fix should be available in the next production build.
- lewis_T
- 269 posts
mabelzileElliot Stronge
This is still broken in H20.5.550, it is doing the same behaviour as Elliot described.
L
- lewis_T
- 269 posts
- Mohanpugaz
- 170 posts
I think it would be nice to have individual files per recipe, every recepie packed in on single .hda is kind hard when it comes to sharing, what if i would like to share a bunch of recipes to another artist without having to pass on my entire collection?
Also it feels safer to save them as individual files since i don't have to worry about accidently saving one single buggy node into recipe.hda which may break my entire collection, for example if i copy over recipe made in H20.5 and add another recipe to that from H21, that is causing some warning, this could entirely be avoided if they are saved in individual files, just like how hdas can be saved individually for each tool.
Any thoughts? or is there a way that i could already do this?
Mohan Pugaz
movfx
movfx
