Viewing through /stage camera with BG in SOP Create LOP
   320   1   0
I have created an arbitrary camera in /stage with a BG image. I append a sop create, so the camera is piped into the sop create. I want to look through that camera in the SOP context, with the supplied BG image. This works fine in H21, does not in H22.
I also tried this:
  • Camera Import SOP - still can't see the BG image
  • LOP Import -> Unpack USD SOP - this does not even need to be wired into anything and you can see the camera in the menu. (I can't believe this works, Gemini suggested it and I thought it must be hallucinating.) However, no BG image.
Is this just broken? H22.0.368
Edited by mrCatfish - Oct. 29, 2026 17:33:28
Sean Lewkiw
CG Supervisor
Machine FX - Cinesite MTL
in H22.0.473 diving into SOP Create LOP or SOP Modify LOP still shows the LOP level camera with BG Image for me, even updates when animated
as for cameras imported as SOP level camera primitives, I don't think they support background images yet
CG Supervisor
Framestore, NY
