Render Flipbook : Change jpg quality
440
7
1
julca
Oct. 25, 2026 5:34 a.m.
When saving jpg from viewport while using render flipbook, jpg are heavy (maximum quality).
But I didn't find any parameter to tweak that.
How to change jpg quality ?
When rendering hundred and hundred of screen previews, size matter.
Thank you.
protozoan
Oct. 25, 2026 9:05 a.m.
You may consider using the FlipbookROP instead (it's new and shiny). That one has a quality setting for its output files, including JPEG.
Martin Winkler
julca
Oct. 29, 2026 6:13 a.m.
Thanks for your return @protozoan,
Now I can set jpg quality !
I still can't succes to get same visual as in lop viewport (without any light).
Any idea if it's possible ?
cf. joined example scene file
demo_01.zip (2.7 MB)
malexander
Oct. 29, 2026 9:30 a.m.
There is a "Lighting" parameter in the Lighting tab which you can switch to "Off", and that will produce the same result as the viewport set to "No Lighting".
julca
Oct. 29, 2026 1:42 p.m.
Sadly when I set lighting to "Off" I got same shaded render. (you can test it in scene file in previous post)
protozoan
yesterday 10:40 a.m.
julca Sadly when I set lighting to "Off" I got same shaded render.Seems like a bug, the no lighting setting always seems to render with default lighting (for both OBJ and LOPs sources). Go file a report!
Martin Winkler
julca
yesterday 10:56 a.m.
Ok, Reported !
julca
today 5:06 a.m.
SideFX Support fixed this in Houdini 22.0.489 !
