Seamlessly Looping Noises
   454   5   0
I've been trying to loop noises seamlessly at a particular frame (typically, $FEND). I've had some success using AI to help. However, the solutions are complicated and don't generalize well. Is there any well-known methodology to create seamless, looping noises in Houdini?
Greg
Hi Greg,
you could grow your own torus noise in SOPs (see attachment), use the fractal noise COP (which is set to torus by default), or perhaps look into periodic noise in VOPs.
torus_noise.hiplc (349.6 KB)
Konstantin Magnus
Hi Greg,
Will give it a look! Thanks!
You can simply loop the offset for any noise.
Something like this:
Offset X: cos($FF/ch("../loop_frames")*2*$PI) * ch("../radius")
Offset Y: sin($FF/ch("../loop_frames")*2*$PI) * ch("../radius")
Konstantin Magnus
Hi Greg,
Thanks, I analyzed the hip file and I (mostly) understand what you have done. Very nice and clean!
Greg
GregBollella
Thank you. I added a simpler version using the carve node and VOPs to make it more accessible.
torus_noise_01.hiplc (381.3 KB)
