I've been trying to loop noises seamlessly at a particular frame (typically, $FEND). I've had some success using AI to help. However, the solutions are complicated and don't generalize well. Is there any well-known methodology to create seamless, looping noises in Houdini?
Greg
Seamlessly Looping Noises
453 5 0-
- GregBollella
- 67 posts
- Konstantin Magnus
- 755 posts
Hi Greg,
you could grow your own torus noise in SOPs (see attachment), use the fractal noise COP (which is set to torus by default), or perhaps look into periodic noise in VOPs.
- GregBollella
- 67 posts
- Gaalvk
- 127 posts
- GregBollella
- 67 posts
Konstantin MagnusThanks, I analyzed the hip file and I (mostly) understand what you have done. Very nice and clean!
Hi Greg,
you could grow your own torus noise in SOPs (see attachment), use the fractal noise COP (which is set to torus by default), or perhaps look into periodic noise in VOPs.Image Not Found
Greg
- Konstantin Magnus
- 755 posts
GregBollella
Thank you. I added a simpler version using the carve node and VOPs to make it more accessible.
