H22 Wayland on Linux support?
5999 30 5-
- Drewzee
- 53 posts
Not to dog pile but I'm starting to run into some quirks with X11 on Pop OS 22.04 (its basically ubuntu). So I'm adding a +1 for Wayland. Pop OS is so much better than Windows though. Zero crashes in COPs on 22.0.429. Windows crashed constantly, especially when screen recording. But without wayland screen recording is still really really bad/choppy.
- TheNotepadShow
- 113 posts
DrewzeeWhat quirks are you running into? I am on a new install of Linux Mint 22.3, with the 615.71.09 Nvidia drivers, and have been rock solid. I don't use Karma though, I use another hydra-delegate. I can see if I get these quirks if you want to do some testing, since we are on similiar distros?
Edited by TheNotepadShow - Oct. 18, 2026 11:41:52
- chf
- 217 posts
Drewzee
What quirks are you experiencing?
I am also on PopOS! 22.04 here but mostly smooth.
Is it specifically with screen recording?
- laggster
- 3 posts
CachyOS has been absolutely wonderful to use for Houdini. (also completely eliminates the NVIDIA pain) but the thing is I use Cinammon which is X11.
H22 is incredibly fast I'm chocked how slow it was on Windows. first time startup is very fast and the softfware is silk smooth in every aspect.
Honestly it's the only thing that keeps me from switching to Wayland, X11 is stable yes but very old and maybe only us are left using it lol, almost all the distros are Wayland now.
I do really hope SESI switches to it. I rather get a native support than using a compatibility layer. I haven't tried XWayland but it seems it causes users some few issues for UI and navigation.
SESI already has one of the best engineers out there, you already standout more than any company in the same field so here is to more of that, get that Wayland version out there wizards!
Edited by laggster - Nov. 14, 2026 11:04:42
- Mirko Jankovic
- 326 posts
Seems like with latest nvidia driver updates houdini is again unusable on Wayland and linux (im on nobara). it is freezing non stop.. I know that suggested drivers are rather old ones but.. seems like no other option but to revert back to older versions.
Anyone else having similar results or?
It helps if using started with __NV_DISABLE_EXPLICIT_SYNC=1 with NVIDIA 620.70.06
Edited by Mirko Jankovic - Nov. 18, 2026 06:41:10
- chrisc
- 19 posts
Mirko Jankovic
Yes, thanks Mirko, same problem with the latest nvidia drivers on Arch Linux (for 22.0.508, nor for 22.0.466) and with __NV_DISABLE_EXPLICIT_SYNC=1 added in houdini.env it seems to work now with 22.0.508.
- tommygdawg
- 19 posts
Mirko Jankovic
Back here to report I'm once again having issues. Very frustrating. I've been having no issues for so long I almost forgot this was a problem. Unfortunately, this fix seems to fix the freezing but causes the UI to bork and go black every so often, and I'm getting vulkan errors in cops. Sigh.
- Mirko Jankovic
- 326 posts
- tommygdawg
- 19 posts
I feel the exact same way. Does anyone know what changed in 22.0.508 that is causing the issue to reappear? 22.0.466 still seems to be running okay for me. Unfortunately, COPs seems to be pretty crash happy for me in 22.0.466 for some reason, so it's a give and take. I also downgraded my nvidia drivers to 615.78.08. It didn't fix freezing in H22.0.508, but we'll see if it helps with COPs.
I'm on CachyOS btw.
I'm on CachyOS btw.
- chrisc
- 19 posts
- tommygdawg
- 19 posts
chrisctommygdawg
Yes same problem with the UI going black for a few seconds with H22.0.508, occasionally, but no problem with 22.0.466. On Arch Linux.
Same here on Cachy. Unfortunately, COPs seems to be VERY crash happy on 466 for some reason but is okay on 508.
