Exporting Packed Geo: How to keep the same pivot as Houdini?{[SOLVED]}
   257   3   1
Hi!
I packed and translated 2 geos. When I export to alembic and into Maya, the geos are in the good world positions but their pivots are at the center of the world. How can I get the pivots to be where the packed points are? I tried playing with the prim intrinsic pivot but it moves the geo... I'm confused.
Edited by olivierth - Nov. 25, 2026 09:39:40
-Olivier
AH! Found the solution. It had nothing to do with the primitive intrinsic pivot.
All I had to do is change the Packed Transform setting to Transform Geometry. Now, when I export and import in Maya, there's a gizmo at the center of the pig and at the center of the rubber toy!
Edited by olivierth - Nov. 25, 2026 09:38:54
-Olivier
usually its better to use Merge With Parent Transfom option as long as your path attrib is unique per packed prim, since Transform Geometry appends ugly _Packed and _Instance suffixes so it messes up the hierarchy naming
CG Supervisor
Framestore, NY
What I'm showing is not my actual situation (can't show company assets).
My real situation is, I've got many geos that I packed and used the Labs Align and Distribute to offset them. I needed a way to export that to Maya with the pivots inside each geos. My solution works for that.
-Olivier
