HELP: Depth map shadows are really grainy if you scale up
   5849   4   1
I m using a spotlight with depthmap shadows(512,512 not transparent) pointing to a plane. If i scale the scene up 100times i get a really bad grain. If the scene is 1 unit i get a really clean image. Is this a bug or what?I ve never seen any 3d program where the depth shadow map quality depends by the scale of the scene. I also set the clipping for the shadow maps to the minimum range necessary to get a better quality map, but it didn t solve the problem at all.
I hope anyone could help…
Sergio
grain.hip (157.9 KB)
it seems that shadow bias has affect on this
just scale it up by the same factor
CG Supervisor
Framestore, NY
Shadow bias is in scene units so if you have a huge scene, you need to compensate accordingly.
It's a part of the game when dealing with depth map shadows and the limited precision available.
Thanks a lot…the explanation helped me.
Sergio
Sergio
