Couple of basic pyhton questions
   32349   48   1
Look at hou.Node.addSpareParmTuple and hou.HDADefinition.addParmTuple.
Great that works. There is a minor problem with the layout if I use a folder.
What is going on there???
obj = hou.node(“/obj”)
camera_node = obj.createNode(“cam”, “my_camera”)
hou_node = camera_node
myTemplate = hou.FloatParmTemplate( “myparm”, “My Parm”, 1, default_value), naming_scheme=hou.parmNamingScheme.Base1, disable_when=“”)
hou_node.addSpareParmTuple( myTemplate, in_folder“Convert”), create_missing_folders=True)
Jobless
Hey Macha,
Add , after “Convert” in this line hou_node.addSpareParmTuple( myTemplate, in_folder“Convert”), create_missing_folders=True) and it should work.
If you write it without comma python thinks that this is sequence of elements not one element in sequnce.
Yeah, what Swann said. The in_folder argument expects a tuple of folder names to specify exactlly which folders/sub folders to insert the parameter in. For example, in_folder'Render', ‘Shading’) would put your parameter in the Render->Shading folder on an Geometry node.
When I create new nodes via Python, can I wire them up with each other? How?
Jobless
Look at hou.Node.setFirstInput(), setNextInput(), setInput().
Cool, that works.
and how about setting a nodes color? It isn't documented. I tried
col = hou.Color.rgb(0.6,0.1,0.1)
myobj.setColor( col )
and variations of this but it doesn't work.
Jobless
hou.Color takes a tuple of rgb values for the constructor.
col = hou.Color((0.6, 0.1, 0.1))
mynode.setColor(col)
I highly recommend looking in the *toolutils.py modules in $HH/scripts/python to see good examples of a lot of common operations like these. A lot of the stuff has comments and it can be interesting to see what Houdini is doing under the hood.
New Question:
I have a bunch of copy-stamped objects.
Is it possible to access those objects through python and manipulate them (for example: scale the object that was copy-stamped at point 3)?
Jobless
