if i have a curve (act as a path) then i want to copy/duplicate an object (ex : torus) along the path, but i want each of this copy will have its own orientation following the shape of the curve. what OP should i use?
kind like copy OP, but i want the orientation follow the path/curve and i want to control the number of copy- that will be distrubuted along the path.
clay~
copy to follow path
5725 6 1- clay
- 58 posts
- mikela
- 27 posts
As far as I know this isn't as straightforward as it may seem. Here http://www.odysseus.anderson.name/mikela/Houdini/RotateToNormal.hipnc [odysseus.anderson.name] is my solution. Basically I take the curve and resample it so I can get a good approximation of the tangent to the curve by comparing the position of adjacent points. I do this by giving a Point SOP two inputs–the resampled curve, and the resampled curve resorted with a -1 offset using the Sort SOP. In the point SOP I add normals $TX2-$TX, etc, and then with the Copy SOP I make sure “Rotate to Normal” is checked.
This technique leaves something to be desired. The uv's are messed up and the surface isn't smooth. I don't know exacly what you're looking for but you might have better results with the Skin SOP and a 2D cross-section.
Mike
Mike
- michael
- 66 posts
- clay
- 58 posts
yes i used sweep before, but the problem : i cannot control the number of copy ,it's controlled by the number of cv of the path, so i have to change the number of cv everytime i want to add a copy and it's hard to distributed the cv manually accross the path/curve to get the same distance from each other.
clay~
clay~
- deecue
- 412 posts
- clay
- 58 posts
- clay
- 58 posts
mikela
sorry, i tried to open this file , but i got a fatal error msg : segmentation fault.
probably different version? i use apprentice 6.1 fyi.
clay~
