Maya Service Block PDG Issues
   1035   0   0
Hey! I am trying to get the example file for Maya service blocks working in PDG.
First, I create the mayascript service and point it to the correct mayapy.exe in the Extra Arguments parameter of the service.
The service starts up upon cooking the maya server block, however it never cooks the service block send node. It seems to not launch mayapy, as the worker appears to be idle and not using any memory.
I am using this for production tools, and need a fix in order to use maya services instead of the deprecated server method. If anyone has any insight, I would greatly appreciate it!
Attached is a screengrab of the node network and the services tab, noting that the memory usage is at 0.0 and the status of the worker is idle.
