Vex: get list of all nodes in a path?
   963   2   0
Hi!
In a wrangle, is there a way to get a list of all nodes in a specific path? Let's say I want to find all nodes in /mat/MyMaterialBuilder ?
I'm looking for a vex method because I know nothing of python.
-Olivier
Python is the way to go for this
It's impossible with Vex. With Python it's as simple as this:
hou.node('/mat/karmamaterial').allSubChildren()
It produces a list of nodes as objects. And then you can look up any value you'd like by iterating over this list.
my_nodes = hou.node('/mat/karmamaterial').allSubChildren()
an_array_of_node_names = []
node_paths_for_example = []
for node in my_nodes:
    an_array_of_node_names.append( node.name() )
    node_paths_for_example.append( node.path() )
print(an_array_of_node_names)
print(node_paths_for_example)
Here [www.sidefx.com] you can find other things that can be added after the node.variable.
You can do it, believe in yourself. Basic Python can be learned in a weekend.
Edited by alexmajewski - May 11, 2025 03:19:57
