How can I do this procedurally
Create a square polygon, develop it 10 by 10 squares. That is a total of 100 squares - sub-polygons
Then go to edge mode select a peripheral loop and make shrink that the selected loop would be close to the center.
How can I do this procedurally (select and shrink loop)
3552 24 3-
- Artadecram
- 31 posts
- atitimar
- 19 posts
- Mike_A
- 392 posts
- Artadecram
- 31 posts
- Artadecram
- 31 posts
- Mike_A
- 392 posts
- Artadecram
- 31 posts
- Artadecram
- 31 posts
- Mike_A
- 392 posts
- Artadecram
- 31 posts
Mike_A
id you download the file attached to my post a
Yes, and thanks again
In you video it's very easy to be discouraged because you keep showing an example through the demonstration of selected polygons, and I just want edges - that there would be no polygons at all.
Okay - I'll study your video again
- Artadecram
- 31 posts
- Fordencore1966
- 21 posts
Mike_A
Hi
I have partly the same task - how to procedurally select this outer edge?
Your text to link here... [limewire.com]
- animatrix_
- 5100 posts
Fordencore1966Mike_A
Hi
You can do it using the Group Create SOP:
- Fordencore1966
- 21 posts
animatrix_
Mike_A
Did you download the file atta
Thanks!!
Yoy can seу that all selected edge are allocated in the same plane but in my cse i need slect only "upper cut"
Firstly i need to select the original edge - any original edge and then begin to grow it endge in sucha a way
How do you catch the original - initial edge?
How to select all upper cuts without potholes cyclically or in one go?
Edited by Fordencore1966 - May 27, 2025 10:29:25
- Artadecram
- 31 posts
- Arttemplar1942
- 2 posts
Fordencore1966
Yoy can seу that a
The cut may not lie on the same plane - this is a child's version - the cut may "wiggle" or have errors in relation to the cut off section, that is, it is necessary to write a node program so that it would highlight not only ideal "upper cut" but also errors. But the errors should not exceed the "potholes".
It is necessary to understand which edge belongs to the original slice, but at the same time not to have a selection to the left and right of itself that would set 3 edges that are correct for further expansion.... - I remember solving this problem in a different editor before - I didn't solve it.
Edited by Arttemplar1942 - May 27, 2025 10:43:30
- tamte
- 9384 posts
Fordencore1966group it while it is an original edge higher in the stream
Houdini doesn't always preserve edge groups through SOP operations but it may work in your case
however it's difficult to say what operations you did and what your "original edge" looked like before whatever operations followed next
for example:
- Sphere SOP
- Clip SOP: Clipped Edges On (this will output "original" clipped edges in a group)
- Blast SOP: delete a few polygons on borders to create those cavities
the "clippededges" group will contain just the original clipped edges
- Fordencore1966
- 21 posts
tamte
Thanks for help-reaction
The point is that the sphere can be cut at any angle and then several polygons are made on this cut.
That is, there is no initial original edge - after each new slice of the sphere this same slice will be different
It is necessary to select those edges which by their appearance belong to one object (multyedge) and this multyedge should be between two potholes. So it is necessary to select all such multyedges. And group them.
- Artadecram
- 31 posts
Fordencore1966
Maybe first select all the open edges and then subtract the potholes from them
But first we need to let houdini understand what belongs to a slice.
Basically we need to understand which combinations of edges have the same pattern and then we have the solution.
Because as it was said above, the curvature error of the multyedge is much smaller than the potholes.
- tamte
- 9384 posts
Fordencore1966Did you try what I suggested? The Clip SOP will generate the group for you with the slice edges, so doesnt matter that each cut is different as the edges created by the slice will be in that group regardless of whether the holes existed before or were created by deleting some polys after the cliptamte
Edited by tamte - May 27, 2025 19:59:35
